got time to install those LED Bulbs .
Holy Moly, Batman! What a Difference they made.
Enough that I had to look them up.
Dome Light Bulb is a 578 - 150 Lumens
Led Replacement bulb is 44mm Festoon - 440 Lumens
yep, you read that right. 150 vs 440 dome Light.
AND, the light itself is a brighter color palette and more normal appearing to the human high, which makes it seem ever brighter.
Now, this is important. These light fixtures are pretty darn cheaply made. the Bulbs are kinda loose inside the clips that hold them. on this bulb, in particular, it is very important to pay attention to LED Bulb placement. you can aim it forward, backward or straight down.
that yellow part ids the actual light emitting bulb and it is only a small sliver of the circle that makes up the bulb.
SO, Aiming it down, gets plenty of light everywhere.
Remember i said these light fixtures are cheaply made?
For the dome light, get a small screwdriver, standard or flat edge.
Large eye glass screw driver works great.
Place it against the lens itself, on pssgr side of vehicle.
That is where the catch is located.
It only takes a a bit of pressure of to push the catch
back enough so the lens will drop down.
Do not worry, it should not fall out, as there is a hinge on the other side of the lens.
Here is the catch that you move backwards by pressing against teh lens with your tiny screwdriver.
Here is what 440 lumens looks like in the daylight.
Notice those two orange looking spots towards the windshield?
That's my Map Lights. They are on and really look poor next to this new LED Dome Light.
Regarding those Map lights.
The Map light Bulb is a 194/T10 - 25 Lumens
Replacement LED is a 194LED - 800 Lumens
Again, an Insane amount of light. Which, if you really think about it, when you turn on a light switch, you need light, why not get the most like you can?
Changing out those two bulbs is slightly more involved than the come light, I will link to a terrific instructional video on how to do it.
I do want to share how the Map Light Assembly comes out. it reaally is a snap. ( no Pun intended)
First thing you do is open the sun glass holder at very front of the assembly."
(I did not know that holder was even there until I watched the video)
Now grab an 8mm nut driver and remove those two screws.
Probably going to do it by Braille so feel around.
Once you get the screws out of there, then pull one clip towards the windshield to release it.
Now go pull the other clip towards the windshield to release it.
Again, by Braille, and it is so easy to do so do not Hulk Out here.
Your assembly will be held in place by the push clips on the back. They simply push straight in or pull straight out.
Gently pull straight down, with steady, even pressure.
Once you get the assembly out, there are two wiring connections that need to be released.
Once released, the entire assembly can now be placed on your work bench or table.
At this point, get a set of plastic gloves. Once you remove the lens cover, over teh bulbs, there is a chrome cone surronding the bulb that will just fall out. If you touch any part of the chrome, with your fingers, you are toast. The finger prints cannot be removed and the oils, from your finger, will cause the chrome to lift and fall away from the cone.
So get some darn cheap gloves and make your life easy.
Here is the video that shows how to do all this stuff.
A whole set of LED lights for 2021 Ram 1500:https://www.lasfit.com/products/2021-ram-1500-led-bulbs-lights-replacement?utm_source=Social&utm_medium=YTB%20Cha...
www.youtube.com
