Granatelli Motor Sports Drive-By-Wire Throttle Body
Nick@GotExhaust
Preferred Vendor
SC
2013-2020 Dodge Hemi DBW Throttle Body 95MM Direct Bolt On-Drive-By-Wire-Black
Description​
Granatelli Motor Sports is proud to offer their MASSIVE 95mm throttle bodies for 2013-2019 Dodge Hemi Drive-By-Wire applications. Their 95mm throttle bodies are precision machined to exceed the demands required for increased airflow on all Hemi performance applications, both naturally aspirated and forced induction.
Can be used with factory or aftermarket manifolds. Utilizes the OEM harness connector. The increased size also allows for smoother and quicker engine acceleration. There is no need to transfer anything over from the factory unit and the Granatelli Motor Sports 95mm throttle body is designed to work with all intakes, including the stock intake. Tune may be required depending on modifications.
* Designed as a Direct Replacement for Factory Throttle Body
* Fits 2013-2020 Hemi Applications
* 95mm Inside Diameter Outflows the OEM units
* Dramatic Air Flow Increase Across All RPM Range
* Allows for Smoother and Quicker Engine Acceleration
* No Need to Transfer Anything Over From Original Throttle Body
* Works with All Intakes - including factory
* TUNE MAY BE REQUIRED
This is a perfect mod to match up with other mods like headers, full bolt on setups, etc...
We have them listed here
black housing
natural housing
Use promo code "TBSAVE" for a discount and free shipping to the lower 48US
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
MASSIVE 95mm throttle body!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
More air flow, more power!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Reliable easy bolt on power
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Pair this up with headers and a tune for a big bump in power!
