Harmonic balancer torque spec
JJ72
St.louis
Hello, newbie here. I am changing the harmonic balancer on my 3.6 and am looking for the correct torque spec. I saw on some random graph it said 30 ft lbs + 105 degree turn (i'm not sure what that means) and a youtube video said it was 130 ft lbs. Please help!
You need one of these,they go between the torque wrench/rachet and socket,and it is 30lb-ft as step 1,plus 105 degrees as step 2
This is a way to do it with-out an angle gauge,but being as you need 105 degrees,you'll kind of be guessing on the 1/2 way point between 90 and 120 degrees
