Has anyone followed the O5 Fob programming procedure?
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
I was going to program a couple new key fobs. The procedure in the owner's manual seems simple enough to follow, but they do warn you that once you make a change, it erases all existing fobs. Just wondering if that includes the fob you use to enter the programming mode or not. Anyone know?
Smokeybear01
US-NW Coast
Cummins 5.9
You need to use the original factory fob to program any new ones and do all the others at the same time even though they are already working. I can't stress enough that you need to use the original factory supplied key fob and not one that you've already programmed. If the instructions in the owner's manual don't work, check on line. There are lots of slightly varying ways to program new fobs. I struggled with the owner's manual and then the wife went on line and tried something different and it worked on all the non-factory fobs. She still flaunts it over me haha. Good luck, Smokey
Smokeybear01
US-NW Coast
Cummins 5.9
I should add, if you don't have the original fob, you might have to go to a dealer and buy one before you can program your after market fobs.
After programming 3 after market fobs, one for her, one for me, and a spare in case a battery dies, I put the original in my safe deposit box so nothing ever happens to it haha.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
I have an original fob that still works. So you are saying when I use the original fob to open the programming window, to follow that same procedure for that original fob also?
Turn on the key, put on seat belt.
Use original fob to open the programming window.
Press buttons on new fobs so they are recognized.
Press buttons on old fob so it is recognized.
Turn off the key.
Ole Buck
South Alabama
I not sure about your 05 but my 04, I bought a thing from advance made by doorman that plugged directly into my obd2 port. I used two new fobs from amazon and followed the doorman directions and have never had an issue. All i needed was an ignition key. No dealer at all. took me three minutes to program two fobs.
Smokeybear01
US-NW Coast
Cummins 5.9
Thanks Buck, that's good info to know. Smokey
