Has anyone put TRX black wheels on a non TRX?
DamnRam1500
New Hampshire
2016 Ram 1500 Express 4x4
I’m just curious to see how the black TRX wheels with factory Goodyear 35” tires would look on a properly lifted Rebel or regular 5th Gen Ram 1500. Anyone seen this done yet?
gt8684
Louisiana
This is an older thread but I'll bump, I'm curious too... Looks/offset/poke... would be nice once my tires wear out on my Rebel...
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If it has the same number of holes for the Lug studs
& the same size center hole
why wouldn't it fit
make sure the lugs nut shape, meets the shape of the wheel at the lugs
olyelr
Kewadin MI
why wouldn't it fit
I dont think they are questioning it. Moreso just wondering what they look like on a non trx truck.
What are the specs of the majority of non trx wheels compared to the trx ones? If i had to guess, the width/offset would be much better for fitting larger tires than the non trx wheels.
GTyankee
3.0 ecodiesel
There used to be a tire website, where you could try rims on your vehicle
It came up as reasonable image
It is called a Wheel Visualizer
quietpeen
2021 TRX
Hellcat
The trx wheels are 18x9 with 19.05mm offset which is practically the same as all other ram wheels so they will fit on a rebel with no problems.
DamnRam1500
DamnRam1500
New Hampshire
Bump, anyone got any pics of a Rebel or other 5th Gen setup with TRX wheels and tires?
quietpeen
2021 TRX
Hellcat
Honestly besides the fact that the tire itself is pretty much a 35” tire vs. the stock 20” tire on 1500’s which is a 33” tire and the wheel is and 18 Vs. A 20” it won’t look much different for poke, or more tucked in wise than Most ram 1500 stock wheels. I wish I could give you a picture but I can’t.
To add to that I think the trx wheels are the exact same specs as the rebel Wheel. 18x9 with +19.05 mm offset.
Rehsba
North Carolina
2019 Classic Warlock
Just bought a set of TRX beadlock wheels (BLACK) attempting to install on 4th Gen this week, just waiting on parts to arrive. Side note for anyone curious: TRX wheels are | 6x5.5 bolt pattern | 77.8 Bore | 18x9 will update with pics hopefully this week
quietpeen
2021 TRX
Hellcat
I assume the parts you are waiting on are adapters since 4th gens are 5x5.5?
