Headlight issues
alexander122
Toledo ohio
A couple months ago I hit a dear.. it ripped the whole right side assembly out when putting it together I noticed the blinker socket was still there but the clip on the harness that clips to socket is no longer good where can I get a cheap one
Atcer2018
Virginia
The cheapest and probably the easiest way is to repair the bad harness. Cut out broken, frayed or corroded wire and solider in new wire using waterproof heat shrink wrap. Even if you have to repin the connector it’s fairly easy to do.
blue ghost
Pennsylvania
2013 Ram 1500 sport
I would check some of the electrical places on the internet, like Del City(there are others), they have all the major auto manufactures plugs and you could get a new plug and just take the clip off.
Take a picture of the plug, i might be able to tell you what type.
Also Check with Mopar One, Benny might have an idea.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
sometimes you get lucky, when you go into most Auto Parts stores,
they have a section of DORMAN replacement parts.
I noticed that NAPA has a large area of Dorman products & even more parts behind the counter
wrench78
Pottstown
Advance Auto and Auto Zone has a section called 911. Usually have odd factory parts. Maybe check there. Or maybe a local junk yard
