Help finding part for starter solenoid wire?
ABlo22
Wisconsin
I have a 2005 ram 1500 5.7 hemi. I’ve been dealing with starter issues and after replacing my 2nd new starter, I discovered the small yellow power wire that goes to the S Terminal of the starter solenoid was frail and broke off at the harness. I’ve been searching up and down for the harness or one with a pigtail and this image is the closest I could get. Will this work on the small prong for the starter solenoid, or does anyone have a link to the correct part?? Thanks!
jws123
nj
A
ABlo22
Wisconsin
yea they tend to corrode often all i did was get something like this dont have the exact one i used but its just a universal connector. I cut the wire back had enough and crimp one of these on then heat shrink Unless someone from here knows where to get the orig connector.
You’re a king thank you, if anyone finds the original part let me know
cbassrex
