Help, need other A-arms
Schwabe
Germany Winnenden
SRT0
Hello,
my 2006 SRT10 is really low with ground force springs.
now I have the problem that my camber is -5 degrees and more. I bought from Rockauto adjustable ball joints but the hole in the a arm is 47mm if I press out the original ball joints. And the adjustible, ball joints with +/-3degrees has only 45 mm diameter. someone told me the 2006 SRT10 has part oft the frames from the 2500 RAM. So what can I do? Should I build metal ring with 1mm thickness or does anyone knows a fitting a arms for my ball joints or are there completely adjustable A-arms on the market to buy?
thnak you vera much andmbest wishes from Germany
cbassrex
