high output alternator
zspace 92
magnum 318
hi my rig is a 98 dodge ram 1500 with a 5.2 i am looking for a higher output alternator preferably from the junkyard or online
the numbers on my alt are 5602 7912 denso i believe fro what i have read online mine is a 130 amp parts store tell me that 130 is the biggest
so anybody done this or knows what to look for a the yard ?
thank for your help
Z
zspace 92
magnum 318
they are nice but so expensive
i would be fine with like 160 amps
SmokedRam
Zephyrhills, Florida
Hmmmm...dont know where you'd find that bud. Advance's Worldwide Alternators for your truck are 136 Amps...
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Off road rams came with a 136 amp alternator, factory literature suggests a 160 amp was standard but I cannot find one listed.
SmokedRam
Off road rams came with a 160 amp alternator, which could be an option.
Are you absolutely sure of that? The 2000 Offroad Rams list the alternators as being 136 amps.
2000 Dodge Ram Offroad package options: Off-road group LT275/ 70/17 tires; 136-amp alternator; 750-amp battery;transfer case and fuel skidplating; foglamps; 17x8-inch aluminum wheels; anti-spin differential; tow hooks; trailer tow group; travel conveniencegroup; auto day and night rearview mirror; illuminatedvisor vanity mirrors; overhead trip console with computer; rear sliding window; securityalarm with keyless entry; six-way power driver seat; AM/FM/ cassette/CD player with equalizer and six speakers; steering wheel- mounted audio controls; and bedliner
Read more: 2000 Dodge Ram 1500 SLT - Dodge V8 Magnum - Off Road Magazine
Looks like the 360 1st gen Durangos came with a 160 amp alternator and will bolt right up to a 360 in the Ram...I would assume it will also bolt up to a 318 too...
Okiespaniel
magnum, 5.9
Yeah, I corrected my post...old factory literature suggests 160 amps but it was never offered as a production item probably due to costs. The idea being an enthusiast would want to add more auxillary lighting.
Some of the adds I work with are produced before an actual production run. You should read some of the old muscle car adds from the late 60s and early 70's!
BTW, I had been looking for that old road test to verify some info before you posted. Now its saved to my favorites. Thanks!
Z
zspace 92
magnum 318
thanks for all the replies i found one on ebay 200 amps for a 1998 dodge ram 2500 with a 5.9 diesel on the picture it looks just like mine anybody knows if it would fit ?
SmokedRam
Te pullys are different I think...according to Advance the Cummins alternator has a 74mm pully and uses a V belt...yours has a 57mm pulley with a serpentine belt...other than that, they appear identical. clocking is the same and all.
Z
zspace 92
magnum 318
then if i use my pully im fine ?
is so thats great i will buy it
SmokedRam
I cant say yes or no to be totally honest...all I can tell with info on the OEM alternators on Advance's site, the only difference is the pulley diameter.
Z
zspace 92
magnum 318
well thanks for your help i buy and sell alot on ebay so i will buy try it out it and if it doesnt work i will sell it
Z
zspace 92
magnum 318
just for info a 5.9 diesel alt will fit on a 318 the pulley doesn't and the body of the alt is just a little bigger
Z
zspace 92
magnum 318
yes i did and it works and best of all it is cheap 175 cad $ for 200 amp
Bad Habit
Land O Lakes
Modded 4.7l
Theres a local company to me called tenney alternators, they build a nice ho alt for not much more than a oem. They normally build custom for spl stereo guys but I have talked to them and they are selling to diesel guys too, cause with lighting, stereo, and all the addons oem just isnt keeping up. You can find them facebook and they will ship anywhere. And powdercoat any color for additional cost
on tapatalk from my GS3....
Z
zspace 92
magnum 318
thanks i already bought the diesel one
Z
zspace 92
magnum 318
cant see why not look on your alt if the numbers end with 7912 then it is the same as mine then it will fit what i saw at the junkyard the dodge ram Cherokee and Dakota alt all mount the same 3.9 5.2 5.9 gas are all the same so if the wiring fits and it looks like yours it should fit
