HOT part behind fuse panel?
ROtruck
What's this? Gets really hot and takes long time to cool. Normal? Always has done this since I first touched it.
crazzywolfie
under the truck
it is a time delay relay or something like that. on the 91-93 trucks it is what usually keeps the ring around the key lit when you got the door open and for a few seconds after you close the door. as long as you got the door open it will stay hot. not sure what it does on a 90
R
ROtruck
Headlights
No key ring light here. There is an"ignition"bulb by the hazard switch. I think it used to work until I unhooked the buzzer. I first found the pictured part when trying to figure out what's up with my headlights when I turn on the high beams. All the lights go out after a few minutes and come back on when I switch back to dim or shutoff main headlight switch and pull back on only on dim. Used to, they would go out at an exact spot on my route home after about 20 miles in the same slow winded curve. After radiator the lights were the only trouble I've had with this truck in many years of driving until here recently. Thanks for the reply.
R
ROtruck
The part stays hot.even a day after last being cranked.igues it would be cold of the battery were disconnected. No drain on battery ever noticed. I mean like Burns finger. One day after last run
R
ROtruck
Oh yeah, craziewolfie, you advised someone to plug fuel return line in another thread. What does this accomplish? I read where someone else was having the"intermittently" engine kill and return fuel line was mentioned in addition to rotting fuel line s as a possible issue. Would a fuel problem warrant a compression test?
R
ROtruck
For my part I got all kinds of problem s. Getting a wiring diagram for it. Just seen in fuse panel how one of the ignition switch wires is linked to the ac/heater fuse. Well I know I got a good heater but absolutely no ac parts under hood except for the compressor in which case the connector is open and just dangling. So I removed the fuse. Of course it runs. But just beginning to eliminate potential problems esp since a wire from ign switch is linked in fuse to that non existent ac
R
ROtruck
Well it was idling fine and died anyway directly after last post
R
ROtruck
And one of those moments when I know it won't restart because when I turned the key to of f, I didn't hear the idle speed control actuator retract as it should when getting set something that when key is turnt back forward it engages and...
R
ROtruck
I know this is a crazzie thang but I had noticed a burnt spot on one of the red wire in this relay, the starter wire for sure so I tugged at it, but to he whole connector came out... Still running though
R
ROtruck
It continued to idle but tried stumbling twice with that relay unhooked it still runs. No stall just stumbled
R
ROtruck
Main relay
This main relay. Don't know about the hot one under dash. But this one is"hot"to o
R
ROtruck
I replaced the old one with that pictured shiny one a while ago because once when the truck was running I simply touched it and kilt engine
R
ROtruck
But that red starter wire is the only one visibly problematic at the relay
Law M
Hi everyone, I am also experiencing the same issue posted by OP about that round metallic (I'm assuming it is a relay of some sort?) being too hot to touch even after the truck has been sitting (undriven) for 3 days. Is that normal? I don't want my truck to catch on fire, so I'm thinking that I may have to unhook the battery from now on if it's just sitting on the driveway.
crazzywolfie
under the truck
It is just fine. You can unplug the relay if you want. I am pretty sure all it does is power the key light when you open the door and a few seconds after. That is why it is generally hot any time you check it
