How many miles on your 4th Gen Ram
jawzs2
South Jersey
2010 1500 - 188,000 mi
2014 3500 - 332,000 mi
Both with the 5.7, the 3500 needed a timing chain at 190,000, other than the manifold bolts, that is it as far as engine\trans work
Been lucky so far, but I probably just adopted one of Murphy's pups
BuschLatte420
chill water by day, drink beer by night
WNY
2022 classic tradesmen crew cab 6’4 box
5.7L NON E-TORQUE 3.92 gears 4x4
532, one month and a day anniversary today!
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
2016 Ram eco-diesel, currently has 62,000 miles on it
in the last 19 months i have only put 2,000 miles on it, due to illness
This Ram has only been to the dealership for Service & Recalls
jejb
NW Arkansas
My 18 2500 had 44K on it when I traded it on my 22 2500 exactly 2 months ago. Good truck overall. My 22 has 830 miles, 430 of which was driving it home from the dealer.
CamperMike
Peoria, IL
68k now. Rh head replaced under warranty at 58k asking with the exhaust manifold on that side. The lh manifold just started leaking so I'll fix it eventually. Just changed brakes on front and rear as they were worn.
tones2SS
MA
Updating the mileage on my truck,.......
33,200 miles.
2016 Ram Sport 4X4
BuschLatte420
WNY
2022 with 8300
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, True Blue Pearl
Not an update, my 1st post in this thread.
2014 purchased by me in 2017, just turned 105,000.
Runaround
Silsbee
My 2014 Ram 1500 with the 5.7 just rolled 200,000 miles on the odometer. No problems other than the rear end had to be rebuilt because the pinion bearing went out and messed up the gears. No hemi tick, no exhaust manifold bolts broken. I have changed water pump and radiator also. I’m still running the original spark plugs also. Running great still, with no oil usage at 5000 mile change intervals.
Keeping my fingers crossed.
My wife has a 2007 model with the 5.7 and it has 230,000 miles on it and it hasn’t had anything major done to it. It does need a rear main seal and valve cover gaskets. If I ever change the valve cover gaskets I will change the original plugs on it.
