How to repalce T-stat
2K10HemiRam
2K10HemiRam
Hometown: Tacoma, WA Stationed: Alamogordo NM
used this write up today to finally install my 180.......thats been sitting here for a LONG time.
My ******* couldn't find the drain (derr). Called Matt, he knew where to find it! LOL
lol, it is a little booger to find. Having drained a radiator before on my old truck though, I was able to find it quickly.
good thing about this forum..... someone on here has probably already done what you're planning on doing, and are willing to share some knowledge
That's what I love about forums and no matter how trivial some people may think a job is, I'm always willing to throw a DIY down.
I'll nab one asap!
I didn't lose much.....none from where the tstat is at (maybe a drop), most of what I lost was due to pulling the plug out really fast and the **** went everywhere. LOL
That's what happened to me sort of, except I didn't yank it out fast. I pulled it out enough to have a controlled stream then when I turned away for a second...the plug shot out and that's when **** went everywhere.
If you take that pic, I'll add it to the DIY so it's with everything else.
redsand
Spearfish
3.5 Ecoboost
The Jet is going in this weekend, glad I ran across this, I've done one before on an old Chevy I had but its been so long ago it'll almost be like doing it for the first time. Thanks for the write-up.
Hemi Joe
Berks County, PA
Installed mine yesterday. Wasn't sure if I found the radiator drain plug, and the one I think I found was plastic. Didn't want to eff with a plastic plug that I wasn't sure about, so I put a drain pan under the front of the motor. Loosened the housing bolts, it drained a bit, 95% got in the pan, lost maybe a half gallon. Moved the hose and housing out of the way, swapped T-stats, put it back together. 5 minutes at the most. Wiped things up with some degreaser, this HOAT stuff isn't as messy as the old green ****. Mixed up some Zerex/distilled water, backed out of the driveway onto an incline. Let the truck come up to temp with the radiator cap off, kept topping off until the T-stat opened, topped off some more and went for a drive. Runs anywhere from 179-182.
09steve
TN
My first post so I'll start by saying hello,
I don't have to change the fan temp settings with a programmer if I change to a 180* stat? So the fan will not come on until the motor reaches 195*?
Please explain !!:hmm:
Hemi Joe
Berks County, PA
You don't have to change the tune to put in a different t-stat. The only difference is it will open and allow the coolant to flow @ 180 instead of 200.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
The thermostat will open at whatever temp it is rated at. The fan however will not kick on until about 200* unless you adjust that setting with a programmer. This wont affect anything on the highway as you are already getting enough airflow to keep the motor cool, but temps may climb a little higher than 180* at idle or at slow speeds because the fan isnt going to turn on until about 200* at the stock setting.
Strange Ram
How does this effect warming up in winter? I can understand the benefits in summer, but michigan winters can suck.
2K10HemiRam
2K10HemiRam
Well all I can say is that in the vegas winters, which don't get as cold as michigan or alberta, my truck still warms up pretty quick, spits out hot air, and my efan never comes on I believe. The truck runs fine at the normal temp.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
we saw temps down around 0 here in STL over the winter. no issues heating up. Suck it up and put a coat on. LOL (kidding)
Hammer75
Kansas
Got mine on order today, look forward to putting it in, thanks for the DIY
ncgatorram
2020 Ram 1500 Limited
3.0L ECO-Diesel
Installed mine today ... thanks for the DYT. Drain plug was a pita but thankfully didn't make that much of a mess.
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
Got mine this morning, will be re-reading this later!
Lhemi
OKC OK
Works as advertised
Couldn't really tell and different but both my truck temp and BD where running 179-185*
Lhemi
OKC OK
Trucks
Dash temp
