I need help finding wiring pigtails.
Brokedownhemi
denver
My 2016 5.7 is throwing p2323 (ignition coil h failure) and p0308 (cylinder 8 misfire) at or above 1500 rpm. ive replaced spark plugs and coils, and even followed some online advice to replace the mds solenoids, but nothing worked. I talked with a Ram mechanic and he said its likely a PCU or the wiring. Id like to start with the cheap and easy fix buying an ignition coil connector with a bit of wiring hanging out to splice to. The parts department gave me a part number (68440520AA) but when trying to find it online no photos are available and its description is "wiring - three way"
If anyone can help me find the right part or something to help me get the job done I'd be incredibly grateful
Thanks guys
Thanks guys
That's the repair kit you need,i bought one awhile ago.The cars and trucks use the same connector
Thank you! I just wanted to make sure. Didnt seem right to me
Curious on why you think that'll fix your issue though,the connectors don't really go bad,unless you've bent a pin.
B
Brokedownhemi
denver
Theres some light abrasion on the wires too close to the connector to splice, im almost positive its a PCU but i figure this might me worth a try, PCU's are about $900
