I think I'm going to go back to stock
blackout11
alpharetts GA
2011 R/T
I have the Alpine 10 speaker system. It sounds good. I'd like more bass. I just need a box for a single 12" and I'm set.
This is the highs on.
Lows are on.
Sorry I have to tempt you LOL :naughty:
Your lows look a little high looks like they are 10 feet in front of the truck or maybe mine are aimed to low are they projectors cause i have them and mine hit the ground about 3 feet in front of my truck
blackout11
alpharetts GA
2011 R/T
thats a side pic but you get the idea are they aimed wrong oh fogs are on to
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
you don't want that much foreground light from your headlights. Hell, in the retrofitting world, the MH1s (the projectors I use) are sometimes said to have to much foreground.
The more light up front, the less at the end of the road.
(and yeah, we are talking about some **** retentive weirdos that complain about 2ft less of light)
LB3711
Trumbull, CT
3.6L V6
huh? english?
LB3711
Trumbull, CT
3.6L V6
lol thanks for the dumb down lol
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
lol, its all good man
LB3711
Trumbull, CT
3.6L V6
i still gotta tweak mine. I guess i didnt adjust them completly after they moved
blackout11
alpharetts GA
2011 R/T
So who's are aimed right mine or his lol if his then whats wrong with mine.
quietpeen
2021 TRX
Hellcat
i say if they are aimed forward you are doing something right
WhiteExpress
Midland, TX
If you pull up along side a long flat sided building the cut off line should be either perfectly level, or slope down ever so slightly. (assuming you truck is level to the road surface)
People make way to big of a deal out of it. If you're getting flashed all the time, they are likely too high. If you can't see ****, they are to low.
I can't wait to get some projectors... Hey JJ, what projectors did you use for the fogs? Is there a MiniMiro?
blackout11
alpharetts GA
2011 R/T
Ya when i pull up to my garage the projector line is straight they could use to be a tad bit higher but i have no clue how to adjust them . Any one help out as far as where the screws and such are
LB3711
Trumbull, CT
3.6L V6
here the hole at the end of my key. You need a torx bit but don't know the size
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
I used the micros / matchbox - whatever they want to call them....... and I'm going to replace them I think. I want to see if the Minis will fit, if so - I'll put some of those in. They are ok - but.....my first go round with this type of projector and one is a smidge misaligned (can't adjust, they are epoxied in), and I kinda want them to fully match the heads.
7MM.
LB3711
Trumbull, CT
3.6L V6
7mm is allen head I thought it was torx. Not that Im doubting you completely that you play with headlights all the time
