Inner Tie Rod Torque Specs
Sean J Blackburn
Looking for the torque specs for inner tie rods on a 2010 1500. I found the outer tie rod specs with no problem but can't find the torque specs for the inner. Can someone provide me with this number?
Also, should I use some removable thread locker or is that unnecessary?
S
Sean J Blackburn
Finally found it. 125 foot pounds for the inner tie rod.
Will probably use some blue thread locker unless someone says otherwise.
