Installing leveling kit with Air Leveling
mopar1x39
Georgia
I have a 2024 2500 limited with the rear air leveling suspension. I recently installed a leveling kit on the front and don't like the amount of sag that is in the rear. I am trying to find out if there is a way to alter the ride height with the air ride on the rear. I was thinking that their would be a way to re-calibrate what it thinks the normal ride height should be? If anyone has any experience with this I would greatly appreciate the help.
olyelr
Kewadin MI
The air trucks sit quite level from the factory, so i would expect a squated rear if you installed a level.
Rather than tricking the bags into adding more air to get the extra height, i would recommend adding a spacer under the bags for the desired height and then play with the sensor rod lengths to keep it working as should. Ive never looked into them, but there may be a kit available just for this.
Ramsteen23
MA
Check out Revel Links...they offer lift packages for Rams with the air suspension
