Timsdually
Jersey
Cummins
It's not that the dealer does not know there is a problem.
My issue is they had it for 6 workdays and all they had done was disconnect my dashcam as a troubleshooting technique.
I expected more from them in the way of troubleshooting in 6 days.
They did install my Mopar bed step for free, LOL...
Look into loaner vehicle from them or if you are covered for rental reimbursement.
Otherwise, time for a different dealer.
Tulecreeper
Sthrn AZ
Only thing I would add is to make sure the doors are closed and locked and have waited about an hour before pulling fuses under the hood to give time for all the modules to go to sleep. I would also suggest taking a picture of your fuse panel for later reference and as you pull each fuse, leave them out until done as reinserting them can sometimes also wake up a module.
I would also add that if you have a under hood lamp, pull it also. 4.5 amps is about what a average automotive incandescent bulb pulls also.
No sir. Maybe .45 amps, but 4.5 amps would be a 54 watt 12 volt bulb.
Jimmy07
4.5 amps is exactly what the current draw is when one module is waking up all the other modules.
Pull the 20 amp fuse out of the weatherproof fuse holder that is in the big wire bundle by the outside of the fuse box towards the bottom of it first, and let us know if it stops that draw after you pull that fuse.
nevinc
nevinc
Pennsylvania
Hemi 6.4L
As long as I run my truck daily it seems it will start normally with the push button.
I checked my battery voltage with a multimeter today after trying to remote start it and it was at 11.8 volts and would not start remotely.
It does however start normally from inside.
I guess I am stuck keeping it plugged into my battery tender as if it were some sort of diesel on a cold winter's night.
Dean2
Near Edmonton
Remote start will not work at 11.8. Needs 12.1 or more. What was the voltage 10 minutes after you parked? I cannot believe they can't track down that big a parasitic draw. Might be inclined to go to a good electrical shop and make the dealer pay the bill. Mightsee what they have to say about that option.
nevinc
nevinc
Pennsylvania
Hemi 6.4L
Per the notes on the dealer sheet that they gave me when I picked it up last time:
"Verify IOD, verified. Unplugged all aftermarket devices (dash campulling minor draw) Let vehicle sit overnight. Vehicle is pulling .3 amps during sleep cycle. Check service infor for any related TSB's or recalls related to concern. No related TSB's or recalls to IOD issue. Maximus charge/test battery. Passed test. let vehicle sit overnight with dashcam unplugged. Vehicle did not die overnight."
They expect me to believe the dash cam is the issue when I know it is not. It was dying overnight before I even installed it.
Here is a sample of the voltage tests I did on 3/5 and 3/6/24
10:30 - 12.35 Amps
12:30 - 12.05
Drove it 20 minutes to store and back.
14:30 - 12.25
16:30 - 12.45
18:30 - 12.4
20:30 - 12.35
3/6/24
09:30 - 11.9
11:30 - 11.9
13:30 - 11.9
15:30 - 12.15
17:30 - 12.15
19:30 - 12.15
I am retired, I could do this all day every day if I wanted. I should not have to.
Dean2
Near Edmonton
10:30 - 12.35 Amps
12:30 - 12.05
14:30 - 12.25
16:30 - 12.45
18:30 - 12.4
20:30 - 12.35
3/6/24
09:30 - 11.9
11:30 - 11.9
13:30 - 11.9
15:30 - 12.15
17:30 - 12.15
19:30 - 12.15
I think what you are listing is volts, not amps. If I am coorect, your voltages ARE WAY off. You should be 12.7 to 12.8 at full charge. So if the battery sits on the charger and isn't reading 12.7 a few minutes after the charger, should be 13.8 or so with the charger running, is removed then the battery is kackaa. If it is at 12.7 and drops to 12 in a few hours something is drawing a hell of a lot more than .3 amps. On top of that even .3 amp draw is way too high. Should not be over .04 amps or 40 milliamps at rest.
nevinc
nevinc
Pennsylvania
Hemi 6.4L
Yes, sorry VOLTS. I haven't tested the amp pull between the battery and the negative cable recently.
nevinc
nevinc
Pennsylvania
Hemi 6.4L
No, not yet.
I am waiting for the weather to break (poor excuse I know) to begin testing the amperage draw when it is asleep.
I have watched a couple of videos to learn how to get a good reading.
Currently I have a battery tender plugged into it when I am home just to keep it from dying overnight.
I am also going to return it to the dealer (for the third time) to have them investigate as well.
nevinc
nevinc
Pennsylvania
Hemi 6.4L
Back in the shop (third time), guess I will see what they say this time. Still draining overnight.
I installed a battery tender to keep the battery charged until I got over being angry and giving it back to the dealer to see if their mechanics can find the issue with the parasitic drain.
Regardless, this is ridiculous...
chri5k
USA
Diesel
Was the tender one of the Noco permanent install types and left installed when taken to the dealer? If so, $5 says they will now blame the “aftermarket” device installed under the hood.
nevinc
nevinc
Pennsylvania
Hemi 6.4L
I would not doubt it at all. It is a Noco and I did mount it under the hood.
At this point, I would not put anything past them.
They tried to blame my dashcam the last time I had it in the shop.
chri5k
USA
Diesel
The service department motto is “We make excuses, not repairs” is probably a red flag to find a new dealer if possible.
nevinc
nevinc
Pennsylvania
Hemi 6.4L
This is the last opportunity they will have.
I have two-three dealerships in my area.
Being a mechanic myself for the last 40 years, I know when they are shoveling a pile of ...
They either put the effort into it or yes, I will move on to another dealer.
nevinc
nevinc
Pennsylvania
Hemi 6.4L
OK, even though I provided the dealer with the following voltage readings, they say there is nothing wrong with my 2500 RAM. They have had it for nearly two weeks now. Their lack of communication is astounding throughout this process.
2024 Ram 2500
Date Voltage Time
28-Mar 12.51 20:30
29-Mar 12.33 12:45
29-Mar 12.24 19:45
30-Mar 12.06 8:45
30-Mar 12.01 19:45
31-Mar 11.93 8:45
31-Mar 11.92 18:45
1-Apr 11.83 9:00
1-Apr 11.80 21:15
2-Apr 11.72 10:48
3-Apr 11.59 11:15
4-Apr 11.41 8:30
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
2024 Ram 2500
Date Voltage Time
28-Mar 12.51 20:30
29-Mar 12.33 12:45
29-Mar 12.24 19:45
30-Mar 12.06 8:45
30-Mar 12.01 19:45
31-Mar 11.93 8:45
31-Mar 11.92 18:45
1-Apr 11.83 9:00
1-Apr 11.80 21:15
2-Apr 11.72 10:48
3-Apr 11.59 11:15
4-Apr 11.41 8:30
You are stuck in a loop with them. 90% of the time, most dealerships are not going to act upon customer supplied data. They may placate you and then discard it and do whatever they are going to do regardless.
Time to find another dealership or lawyer up
nevinc
nevinc
Pennsylvania
Hemi 6.4L
I'll bring it home and run the exact same test to verify the condition still exists. There was a time when I dropped it off at the dealer and they had to jump start it to take in the shop, they know there is an issue, they are either to ignorant or lazy to figure it out.
Daw14
Go to a DIFFERENT dealer , returning to that place is a waste of your time. Dealers lie. Often. Find a new one.
