Really? That's kick ass! I wonder how that works?!?!?!?
its the same "smart bar" used on wrangler rubicons.
2 things - they dont like water & they're about $1800 to replace if you smash or drown one.
BUT there are fixes, off road evolution has a manual conversion for it that replaces the PC board and electric motor with a thumb screw.
Yeah you have to get out, but it doesnt fry and cause computer problems if you dunk it too many times!
I did a computer over ride for mine on the Jeep and essentially hot wired the electric motor to get it working again.
There's a massive controller card inside there with several processors and the actuation itself is - ok get ready...
an electric motor turning a set of planetary gears with a clock spring attached to turn a worm gear screw drive to push a spring piston to move the actuator button that actually disengages the collar on the 2 piece bar and is held in the unlocked position by a magnetic lock.
Here's a video I did showing more about it
bypassing the electro crap on a Jeep JK sway bar on Vimeo
