- Jan 8, 2015
- 9,190
- 4,943
- Location
- St. Louis
- 2014
- 3.6 Pentastar
For anyone who can help...
I generally know what needs to happen to get an amp installed and have done so before. I currently have a Kicker PXA500.1 running a sub under the rear seats. I'm using a line level (high level?) input from the rear passenger side speaker to feed signal to that amp. Previously, I had an aftermarket radio and had run two RCA connectors to the rear sub amp for input which are no longer used (RCAs still in place which run all the way up to the OEM radio). My first question is, can I use an RCA splitter (see below) to take the input for my rear amp and use that same input to feed the Kicker Key 200.4? I'm just trying to avoid tapping signal somewhere else again.
