Left side is nearly 0,8" lower on my Rebel 2016
shagya
Hungary
5,7 L HEMI
Left side is nearly 0,8" lower on my Rebel 2016 with 45000 miles in any level position.
So the truck stands not horizontal in width without any load and with just empty fuel too.
Allthoug it's not a handycap at driving but looks sily for me.
Had anybody this or similar problem?
Can be fitted with software update of the air suspension?
Thanks
Shagya
CanRebel
Toronto
Are you sure there is no issue with air leaking?
If there is no leaking issues, you could check/adjust with AlfaODB.
shagya
shagya
Hungary
5,7 L HEMI
I think if leaking so would not be possible to rise up the left side at all.
Rise up to the highest position and lowering to minimum works but always with the same difference.
Tomorrow I got an appointment at the mechanics in Budapest for checking the whole system.
Will tell him your advice.
Thanks
Caterpillar
France
Rebel 2016
Hello
I have the same problem, I rectified it with adjustable rods
shagya
shagya
Hungary
5,7 L HEMI
Thanks Caterpillar. Also a good advice. This could be a solution if nothing else helps. I discuss it with the mechanics today afternoon.
chopperman1
2018 Rebel
5.7L HEMI
You can use AlfaOBD to program/adjust your ride height. It's not a leak. If it was a leak the compressor would be running all the time raising the corner as it leaks down.
