Lift Recommendations
BigKoach
Atlanta
I recent bought a set of 24x14 rims wrapped in 33x13.5x24 tires. I’m looking for recommendations on the best lift brand and height for my ‘22 2wd Big Horn. Don’t want to go over 6in lift if I don’t have to. 4-5.5 would be idea height without too much rub
mrack
You don’t need any lift to clear 33s. Most these trucks come stock with 33s
crazykid1994
That wide of a tire may rub when you turn not matter what. Otherwise 33s should fit fine. I would just start with a 2 or 3” lift. @Nick@GotExhaust does eibach offer a 5th gen setup? Front and rear springs. A 3/1 setup should be fine with those tires but may still require a bit of trimming
BigKoach
BigKoach
Atlanta
Thanks for your help
mrack
Yeah what he said, depending on your wheel offset you’ll probably get some rub on the inner fender, possibly the bumper or frame also. I had 37x13.5 on my truck when it was stock once for kicks and giggles, I was shocked how well they fit. Only a little rub on the bumper, if I trimmed that a touch I probably could have gotten pretty close to full lock. Obviously you should have a lot less issues with a 33”. I’d throw a set of bilstein 5100s in at 2.1” to level it and and go from there.
Edit: forgot you have a 5th gen, not sure how the clearance compares. I’d still start with bils though
Nick@GotExhaust
Preferred Vendor
SC
Eibach does make a kit that will lift 1" in the rear and up to 2.75" in the front.
Maxtrac also makes a 4" kit
Message me if you would like a quote on anything
crazykid1994
There you go OP. I would message nick for a quote. Any higher with the 33s and it’ll look like you skipped leg day
