Loose ahifter
85 power ram
LA 360
Since I've owned this 85 dodge the auto gear shifter has been loose, I have to wiggle it into drive, or reverse can't get it into 1st or 2nd, any ideas on what I can do to tighten it up?
crazzywolfie
under the truck
how rusty are the front cab mounts? you can adjust the linkage but if your front cab mounts are rotten then the front of the cab may sink more and start having the same issue again.
