Lowering 2019 That Has Air Lifters/Bags
Shaney G
Seattle
2019 Classic
I just bought a 2019 1500 Classic and it appears that the previous owner put air lifters/bags on it. (See pics) I'm looking at putting the Belltech 2/4 lowering kit on it but I wanted to know if there would be any issues since my truck already has lifters/bags on it?
Only way to find out is try it. If you have clearance issues with the bags , like them bottoming out,then remove them,if not leave them in place
S
Shaney G
Seattle
2019 Classic
My issue with that is that the stock bump stop cups have been cut off to accommodate the lifters/bags. So if the lowering kit doesn't work with the bags in place I'm kind of screwed since I don't have the bump stop cups to re-weld in place, nor do I trust my welding abilities. Was hoping someone here has done a similar lowering job and what their results were.
You can buy bump stops that screw into the hole above the stock bumpstops. Its a fairly common mod if you go lower then 4" and cut the stock cups off.
