Master cylinder Maybe
Barrett Palumbo
Denver
So I lost my breaks today, all is good. No lights or dash warnings. Pedal to the floor if I go slow the pedal will stop the truck. I do have power steering. Truck is 2014 about 90,000 miles on it. Thinking the master cylinder has an internal seal issue, i have no loss of fluid…. Any thoughts…
Dodge 1500 4X4
Rochester, NY
As long as there are no leaks sounds like the master cylinder is bad, make sure you bench bleed it first, hopefully ABS isn't effected.
