Mirror module
Caterpillar
France
Rebel 2016
Merci Benny
Mais je ne trouve pas les pièces sur votre site Web
Caterpillar
France
Rebel 2016
[QUOTE = "Caterpillar, post: 2435732, membre: 107617"] Commande passée
Merci [/ QUOTE]
Bonjour Benny
J'ai reçu ma commande de miroir, merci.
J'ai besoin de code pour les faire fonctionner merci
Hilderman85
Regina Saskatchewan
Hey Benny,
I have a 2013 Ram laramie vin # 1 C6RR7NT7DS576050.
It has the power tow mirrors that do not fold.
I have a buddy with the 2017 Laramie with the short 6x9 folding mirrors and we want to swap.
Can I just swap the mirrors / modules / controls and it will work? or do I need to flash both vehicles?
Thanks!
-Andy
Ricks Ram
Hey Benny,
Thanks!
-Andy
You will need to enable the LER power fold mirror code. In many cases the dealer cannot enable this code because your truck came with Tow Mirrors. You can also easily enable this code with the Alfa OBD app. He will need to enable the Tow Mirror codes in his truck if he currently has non Tow Mirrors. This is so the mirrors will adjust correctly when in the up position.
Sent from my SM-G981U1 using Tapatalk
Hilderman85
Regina Saskatchewan
And doing the straight swap of the three components (mirrors/modules/button controls) will work as long as we change the codes on each truck?
All
All
Yes all parts are interchangeable. The only thing that may be of issue is the switch. There is a 2013-2015 version and a 2016+ version. So if you need the switch for your 2013 its part # 68298867AA
-Benny
Ricks Ram
Exactly as Benny said. You will most likely need to.putchase new master switches because they changed the wiring harnes for the switch from two connectors to only one connector. Everything else is a direct swap and then enable the proper codes.
Tx2500
TX
2017 RAM 2500
6.7 CUMMINS
@AllMoparParts.com
Hello, so i recently made a purchase for power folding mirrors on a '17 ram 2500 Vin#3C6UR5DL0HG725413 I need some assistance on which modules ill need for both doors. Thanks in advance.
All
All
@AllMoparParts.com
Hi,
Use 68225103AD and 68225102AD modules
Please let me know if you have any questions.
Thanks,
-Benny
93-331-29psi
Virginia
I am looking at adding the power fold but drive a regular cab and not sure if the door switch is available. Could you assist with module and switch part numbers
VIN
3C63R3AL0JG361598
Dja0550
East Coast
2019 classic
Hello Benny,
I just recently purchased a 2019 ram classic with power mirrors with heat and manual fold, i am looking into upgrading to tow mirrors with power fold and turn signals and puddle lights. Besides for the alpha one and the bypass for the obd reader, what part numbers would I need to complete this? My vin number is:
1C6RR7TT6KS625013
Thanks
All
All
Hi,
You would use the following modules
And here is the illuminated optional switch which most prefer
Thanks,
-Benny
Dja0550
East Coast
2019 classic
Thanks! Glad to get your help, I had my truck plugged in so it was saying they didn't fit my truck so I was confused
