My 2019 Ram 1500 is continuously beeping!
KKRR
hOUSTON
I went to the Walmart with the vehicle with no issues but then afterwards I started the vehicle and it started to constantly sound an alarm with no breaks. I turned off the vehicle, the radio, the sensors and still nothing. Since I didn't see any issues on the dash, I drove the vehicle home with the constant sound. Even after I turned off the engine and locked the doors I can hear it ringing inside the vehicle. Anybody had this issue before?
Tulecreeper
Sthrn AZ
I'll assume there are no alerts on your screen. I'll also assume that when you say "it started to constantly sound an alarm with no breaks", you mean that the alarm is constant instead of beeping.
K
KKRR
hOUSTON
Yes, constant sound that had no breaks and no codes on the dash. A week ago I had my battery and fuel pump replaced at the dealer. So everything should be good.
Tulecreeper
Sthrn AZ
Start by disconnecting your battery, waiting about 10 minutes, then reconnecting it. It's like restarting/rebooting your home computer. After that, assuming that fixes the problem, it may need to be driven for a while before the system resets itself. If after 20-30 minutes of driving it is still doing it I have no other suggestions, but I know there are those on here who will.
turkeybird56
Central Texas
Disconnect battery negative terminal behind IBS for at least 2 hours 4 if possible. U may wanna make sure battery at full SOC while disconnected. When U reconnect it will take maybe as much as 5 drive cycles before all the modules synch and talk to each other.
Tulecreeper
Sthrn AZ
Why such a long disconnect period, Turkey?
turkeybird56
Central Texas
Wat I was advised by Lead Tech at Dealership when I had a problem with my TIPM directed charging rate when battery was replaced on MY 19 in Feb 2023.
tron67j
Maryland
Should scan for codes first if you haven't already disconnected. However, once you reconnect the battery sine fixes require a few cycles of on/off/run before warning lights stay off for good.
Good luck.
K
KKRR
hOUSTON
Thanks everyone but I think I found the issue. It was at the OBD port. I have a drive snapshot reader in my OBD port that when removed solved the issue. The sound was from the vehicle but I'm guessing the device failed and the vehicle was beeping due to it. Hopefully that fixed the problem.
