My ol W250
K
Kevin Fowler
California
Does anyone have a photo of the front of their motor? I pulled the water pump, and because of life I couldn’t get back to it right away. So I just want to see how one bracket goes.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
I'll try to snap a pic of my 92 318 tomorrow but with the fan shroud, not likely to get a good pic. can you post a pic of the bracket in question?
K
Kevin Fowler
California
I am pretty sure it’s for the smog pump. But one side is longer than the other
reek
Sacramento
can't get any better pic of my engine than what I can find on line. but that part is for the air pump. when I deleted mine, I threw that part away. it can be seen in this diagram.
K
Kevin Fowler
California
Appreciate it. I’ll probably get back to it next weekend. I’ll let you know how it goes.
K
Kevin Fowler
California
I started to get it back together but I’m stumped. I shouldn’t have waited this long or at least taken better pictures. I have these two brackets that need to go on still.
Daw14
The upper part looks at the timing line on the harmonic balancer.
K
Kevin Fowler
California
Got everything back together! No leaks! Going to have to replace the harmonic balancer, it is not "balanced" at all lol. Smog Pump is seized up and melted the belt to it. So I just cut the belt. I'll replace it before I get it smogged.
reek
Sacramento
what did these parts turn out to be. specifically the first pic. i have about 3 or 4 laying around and don't remember where I pulled them from. yet both of my trucks are running just fine. for now.....
K
Kevin Fowler
California
The first one goes at the bottom of the water pump. To check timing. You can see the rounded end inside the yellow picture. The bottom picture helps hold the AC and Alternator.
2012RAM1500RT
nowhere
I had an '87 I had as a work truck. It was a Va State service truck and I bought it for $3000 back in '91 and used it till '98. Had the 360 4 bbl carburetor and automatic transmission. I really miss how simple they were. Nothing luxury, just a man's truck!
K
Kevin Fowler
California
I’m loving it. I need to get it back in its proper form. Totally agree very simple, except two stupid little brackets
K
Kevin Fowler
California
It is time to tackle changing the harmonic balancer. Has anyone changed one before? Looking for tips or do's/dont's.
reek
Sacramento
it's been a while but I'm pretty sure it's straight forward as long as you're seal is good. use plenty of lithium grease on the seal when installing. just need plenty of room.
K
Kevin Fowler
California
Probably have to remove the radiator then? Or is the fan enough?
reek
Sacramento
I actually did a complete motor rebuild so I did my balancer with the motor out. But when I was trying to 'clock' the motor to TDC, there really wasn't much room to work even with the fan off. Can't easily reach the balancer from below because of the core support and anti-sway bar. So I ended up removing my radiator and fan shroud for more room and so I don't accidentally destroy the radiator. Luckily I hadn't filled it yet. I'd say if you're going to be using a puller and in general, may be better off pulling the radiator. Not much work plus you can give it a good flush while it's out.
K
Kevin Fowler
California
Lovely lol sounds like it shall be fun! appreciate the info!
K
Kevin Fowler
California
Got the radiator out and the pulley off. Didn’t have the tool to pull the balancer out. Hopefully get that out soon.
K
Kevin Fowler
California
This truck hates me.... I got the harmonic balancer out, got everything put back together. Still doing the disco down there. So if I am correct, my crank has gone bye bye....
