Need belt diagram help for 2017 2500 6.4 single alternator.
wgreggking
rural Arizona
2017 4x4 offroad
I have a 2018 diagram, no belt diagram under the hood. I have a new belt, got the gates. Removed the oem belt, and cant seem to get the new one on. spent several hours trying to solve this. The new belt is the same as the oem length.
pacofortacos
Also, if the pulley has a smooth surface then the back of the belt rides on it, if grooves then the grooves on the belt faces those grooves.
The link above is pretty good and should help you.
