Need Help with Uconnect 8.4 Update
Ashton
VA
'18
Hi, I like most people have had my Nav stop working/not accurate on my 2018 Ram 1500 after the Nov 3 2019 roll over. My gps shows me like 3 states away and I would like to finally have this fixed. Truck has the factory 8.4 uconnect with nav. Software version is 17.43.44 and the truck is originally a Canadian truck. App version 19.9.0
Hoping someone has the update file so i can do it manually because according to uconnect im "up to date"....
Thanks
Ashton
Ashton
VA
'18
Yea I made a few attempts
Ashton
Ashton
VA
'18
Anybody else?
Toronto, Canada
Having same issue with NAV. I swapped 2018 radio into my 2013. Right away NAV was frozen and not updating my current position. Were you successful performing soft reset? How do you do it? What about hard reset?
Original firmware says it has 18.13 version on it. Would like to upgrade to the latest and see if it fixes anything.
Atcer2018
Virginia
I know it’s not a real fix but don’t all the 2018 and up 8.4 radios have android auto and CarPlay for navigational use? Being a little OCD myself I’d want a permanent fix but AA and CP offer a compromise until a permanent fix becomes available.
chri5k
USA
Diesel
Here is the roll-up thread on updates.
khocke
Western Catskills, NY
Software updates will most likely not fix the GPS problem you are having. There is a cellular daughterboard in your radio that is probably fried. This is just my experience.
Ashton
Ashton
VA
'18
Yea when i go on a trip ive been using android auto but it would be nice to have this working properly
Ashton
Ashton
VA
'18
Thanks for the link but that seems to be only for the 13-17 headunits.
Ashton
Ashton
VA
'18
Is this inside the headunit or somewhere else in the truck?
chri5k
USA
Diesel
Ooops wrong firmware thread. Here is the one for 2018+
And here is another for the 2019+ radios.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Vin check says i'm up to date which is not possible.. it's never had an update since new
Did you have the chance to read this thread
They use the USB flash drive method but do not dump everything at once just one file at a time.
Rayzaa
Las Vegas, NV
Thats what i use, i dont bother with the factory Nav at all.
