New to the D150 Ram world
CB_Fan
Just inherited a 1988 Ram 4wd long box. It looks like the truck sits pretty high for a stock setup.
I am wondering if it has a 3/4 ton leaf spring setup. There are no lift blocks, or any other signs of a lift kit. Pointing me towards the leaf spring thing.
How can I tell the difference?
Any help is appreciated, thanks.
Kris
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
welcome to Ram D150s!
you seem to have a 6 leaf spring stack, usually load rated for approx 2500 lb. I think the "standard" leaf pack is 5 leaf stack rated about 1000 lbs less than 6.
C
CB_Fan
Thanks for the reply. I haven't driven it yet, but I'm guessing it will ride like a lawn tractor.....
u2slow
BC, Canada
Cummins 6BTA
I forget if they were 2 or 3 leaf in my ramcharger. My old w300 was 5 leaf. Cummins is 6. Those have more curve than a Cummins pack.
crazzywolfie
under the truck
Looks like it likely has a lift kit. Pretty sure mine is stock and the leaf springs up front are pretty much flat under the weight of the suv
