No Tow Hitch
Warlock2024
Warlock2024
Northern VA
V6
U need to research and make sure u get the correct one for your truck since Mopar site does not show yer trim. I would bet it fit but u need to get correct fitment for your specific trim
Got it! Just so I'm clear, a Class III Bumper Hitch is not actually a hitch, more of a hole cut out to add one? This is my 3rd truck and never had one without a hitch on it so I just want to be sure.
turkeybird56
Central Texas
turkeybird56
Central Texas
Above looks like u need to fit yer Warlock specific but u gotta look and verify and make sure if u get it u get it with receiver part also.
Good luck on all that
turkeybird56
Central Texas
The Hitch is the bar with metal ball attached: That U slide into the receiver. Mounted on the truck.
The receiver is the entire assembly with the square hole mounted to truck u slide the ‘hitch’ into.
The receiver is the url I posted in post #22.
U need the entire receiver with the hitch receiver attached there are 2 pics in the mopar part see the one with the square hitch slide as part of receiver group. The square part in the pic.
turkeybird56
Central Texas
U need the entire receiver with the hitch receiver attached there are 2 pics in the mopar part see the one with the square hitch slide as part of receiver group. The square part in the https://duckduckgo.com/y.js?ad_doma...650553B4B6473021744253AAD656A&ID=DevEx,5087.1
turkeybird56
Central Texas
Remember gotta match hitch ball and slide to match trailer. They usually start at 5K capacity and move up. I have a 7,500 lb setup which matches my stock trailer total capacity plus 20% ability for safety. Not want a lower slide compared to wat I pull.
