- Joined
- Sep 15, 2022
- Posts
- 379
- Reaction score
- 492
- Location
- Olive Branch, MS
- Ram Year
- 2016 Ram 2500
- Engine
- 6.7
Hello Ram Forum Members!
New website for the No Splice Kill Switch Harness is now available at: LINK Accepting Paypal, Credit cards, G-Pay, etc.
Update: 1/7/2023 - A new search tool for finding a kill switch harness is now up on the website. If you're looking for a kill switch solution, come check it out!!
If you have Chrysler, Dodge, Jeep or RAM - we most likely have a kill switch harness for you!
Here's a list of other vehicles we have kill switch harnesses for - HERE
Please check out my How to install a No Splice Kill Switch Harness instruction located - HERE
For those who've already reviewed my original thread Hello Everyone! from JW2 Innovations I wanted to put a shorter thread together on ordering one of these No Spice Kill Switch Harness'
We now offer ready to install kits for both our 1 kill switch harness, as well as our 2 kill switch harness which you can find by searching on the website for your year/make/model.
These kits include the following items:
- 1 Kill Switch Harness kit includes the 1 kill switch harness, 4.8mm ends w/heat shrink attached, and a 20mm rocker switch.
- 2 Kill Switch Harness kit includes the 2 kill switch harness, both harness leads with 4.8mm w/heat shrink ends, and 2X - 20mm rocker switches.
You can still order the 1 kill switch harness, and the 2 kill switch harness as we've always had to create your own custom solution. Adding 4.8mm blade ends w/heat shrink, the 6.3mm blade ends w/heat shrink, and both the 4.8mm post rocker switch, as well as the ready to solder 20mm rocker switch as we've always sold if you are doing something special with your install! All of these are under your vehicle type when you search on the website or use the links above.
The 1 kill switch harness starts at 2ft with 20awg copper tinned wire wrapped in black harness cloth tape with options all the way up to 10ft.
The 2 Kill Switch Harness starts at 2ft with 20awg copper tinned wire wrapped in black harness cloth tape with options all the way up to 10ft!
Add on options at the time of ordering your harness:
4.8mm or 6.3mm blade ends crimped to the end of the harness with heat shrink is available.
Photo is for comparison of the two different sizes.
Example with 4.8mm blade connector ends added w/heat shrink
Example with 6.3mm blade connector ends added w/heat shrink
Round Switches offered - using 20mm hole in each round switch below:
Round Rocker switch 2 pin with soldered cable and connections w/heat shrink (you would simply solder this to the long cable of the harness if you prefer this approach, or use butt connectors instead of solder if you chose - while installing your hidden switch)
Round Rocker switch 2 pin and 4.8mm blade connectors.
Once you have determined the harness with options above please place your order by one of the following methods:
1) (Fastest method) Use the new website for the No Splice Kill Switch Harness is now available at: LINK Accepting Paypal, Credit cards, G-Pay, etc. Make sure you create an account and login to the site before placing an order.
Canadian friends - you can now order on the site for your Canadian delivery addresses!
2) Or send me a Private Message (PM) here on this site.
Where to send a PM on this site:
Please include your name, mailing address, and email for paypal so I can get a quote for the total with shipping. Here is an example of what to send me when placing an order.
John Smith
1234 Example Road
Fall Creek, MS 12345
[email protected] (example only)
Example order sent via PM: Harness w/ extended 2ft with 4.8mm end and a round rocker switch without attached wires.
Example of my response to your PM order will be with your actual shipping cost like seen here:
Harness - $34.00
2 additional feet with black harness cloth tape applied - $5.00
4.8mm ends attached with heat shrink - $3.00
Round Rocker switch (indicate with or without attached wires)- $2.50
Shipping (will be your actual cost from zip 38654 to address you provide) Example here - $4.56
Total $49.06
Once you verify your order with shipping I'll send you a Paypal invoice. Upon receipt of payment your harness is shipped out! Tracking via email will be provided so you can see where your harness is at all the way to your house.
Please reach out if you have any questions. I have harness' in hand ready to go!!
John Smith
1234 Example Road
Harness - $34.00
Total $49.06
