P0DAF Code - Issue Unknown
Hvacguy
Connecticut
5.7l v8
My 2019 Rebel has the Check Engine Light on. It reads as a P0DAF - Engine. The suggestion from the scanner software is 60% Replace the battery, 30% Replace the alternator, 10% Replace the starter. There is no indication of any power or starting problems. Is this legit? Much appreciate any comments!
If you don't have one of these,it's worth picking one up,then you can load test batteries,and check the charging system at home.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Ram owners are having this Code show up, whether they have the eTorque System or not
some owners have said that the Remote Start using the FOB no longer works
So check the voltage of the trucks 12 volt battery
