sandawilliams
- May 29, 2012
- 2,799
- 5,530
- Location
- Pueblo West, Co.
- 2021
- 6.4 hemi
I've noticed a problem when parking my 2014 on a slight incline with a heavy load and how I must sequence the actions. If I place it in park and set the emergency brake the next time I start it and try to place it in gear the pawl is locked in and takes a lot of effort to get it out of park. If I reverse the action by setting the emergency brake prior to shifting into park the parking effort works smooth.
Something else I see is there is always a very slight movement when setting the emergency brake. It cant be more than a quarter of and inch but it must be enough to create this problem.
The old drum brakes would lock tight when setting them. The newer disk brakes don't seem to lock immediately on setting. Just a heads up if you are experiencing this problem.
