PLEASE HELP, 87 DODGE W250 FRAME Swap
Braden hunter
Indiana
Chrysler 318
I have a 1987 Dodge w250 4 wheel drive 3 quarter ton and the frame is completely rusted gone I am looking to replace the frame but I have not been able to find that many trucks that are exactly like mine so I was wondering are there any other years or model first gen frames that will work for my truck. Any advice will help thank you
DustyDog99
US
1985 D250, 1986 W150
1985:318-2bbl 1986:318-4bbl
Unless you have an extended or crew cab, pretty much any 81-93 4x4 frame will work. I don't believe there is any difference between 1/2, 3/4, or 1 ton frames. The 72-80 frames may have some differences but would still work in a pinch.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
try to stick with the newer frames. the older frames are a lot less 'beefy' than the newer ones. I have a 78 frame sitting next to a 92. the cross members are way wider and have more 3D forming.
u2slow
BC, Canada
Cummins 6BTA
All the 91.5-93 cummins trucks got an updated 8" channel frame. Unsure if gas models followed suit. Everything before it was a 6" or 7"channel of different thicknesses. Crossmembers and fuel tank straps differ. Found this reference pic on ramchargercentral:frames_dodge_84.jpg
78loadstar
SW ohio
I have a 84 w-350 good frame bad body. 360 runs. sw Ohio if interested let me know and we can work something out.
Dennis
