Pop Quiz 4 - The Hardest One Yet...HINT ADDED.
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
Although I wasn't personally involved in this one, it's too good not to post up. The cause eluded the technicians involved, tech support, the regional technical advisor and even Chryslers engineers. During the final test drive on the day Chrysler bought this vehicle back, the problem was finally duplicated and the cause was immediately found.
The vehicle was a 2004 midline Caravan with a 3.8L engine and 41TE transmission. We'll call the owners Mr. & Mrs. Smith for our purposes and Mrs. Smith was the primary driver.
The problem - Mrs. Smith reported that the vehicle would shut off under medium or hard braking. It would immediately restart and run fine until another similar stop was performed and then it would die again. The van never failed to restart.
Mr. Smith brought the van in to be diagnosed and repaired. After several test drives, the problem could not be duplicated. The technician checked the PCM and other modules for codes and none were ever found. The vehicle was returned to Mr. Smith and he went on his way. A couple of weeks later Mr. Smith was back reporting the same issue. Wiring was checked for intermittent problems and more test drives were performed and still the problem couldn't be duplicated. At this point STAR (Chrysler technical support) becomes involved and they advise the technician about things to check regarding potential wiring problems again but he finds no problems. Mr. Smith takes the van home.
Visit number three - Again, the problem can't be duplicated and STAR advises the replacement of several components such as the ignition switch and PCM. The van is again sent home with Mr. Smith.
Mr. Smith is back again with the same problem. It's discovered at this time that it's never happened to Mr. Smith. Not surprsingly, the problem can't be duplicated.
Fast forward to the day of the buyback. Our regional tech advisor, John, wants to take one last test drive. He hops in the passenger side with Mrs. Smith driving. This time under a hard stop the vehicle shuts off and John immediately finds the problem. What do you think it was?
quietpeen
2021 TRX
Hellcat
Her but was lifting off the seat triggering the safety switch...holy crap that is a tough one
ramhunter9
P-Star Jeep Wrangler
She is over weight or under weight .
RamTech
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
HINT: If Mrs. Smith had brought the van in for service herself, the problem could have been duplicated and found even without her along for a test drive.
tmerritt530
287 ci
Her purse hanging on the shift column shifted throwing it in reverse.
Sent from the palm of my hand
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
She freaked out when braking hard and turned the key off.
tmerritt530
287 ci
Run low on fuel and got an air pocket?
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
It's a woman driving....... Of course its gonna break! Lol jk!
Proven fact that men drive better than the opposite sex! Jk
Sent from my ADR6350 using Tapatalk
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Something with her seat controls shorting out and making it shut off
RamTech
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
Nope. This theory makes sense to a point. Keep in mind that the vehicle was in several times and the odds of it being low on fuel each time are pretty slim.
ramhunter9
She had big breast
RamTech
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
If Tanner and Eddie put their heads together, they may figure it out.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
She was driving with two feet and while braking she was hitting the accelerator at the same time? Causing a safety feature to kick in?
ramhunter9
She didnt have any gas in it duh ... dumb blonde
