Voodoochi1d
Ok so I adjusted gains, and checked impedance of Subs.
Here is the wiring diagram for them.
The wiring is all good, no loose connections, grounds are tight as well. The voltage gauge stays constant at 12.5 to 13v for about 15 to 20 minutes, and as long as I keep volume on radio below 15, the voltage gauge never drops below 11 on long deep repetitive bass hits. Once the RF P500-2 warms up (but never been to hot to touch, warm is better description) and the voltage gauge starts to move up and down during bass hits, the amp will shut off (protection light blinks for a sec) and then turns back on. No sound from subs during this time.
Again this only happens when amp is warm, volume is above 15 and bass remote is turned up more than 50%.
What can I do to upgrade or better the charging/power system in my 09 Ram?
Upgrade battery, do I need to replace the alt? Checked and I have a 150 amp alternator.
Does anyone know if the Ram has some sort of regulation that attempts to keep voltage at or around 12.8V? That would explain why when I press on gas pedal, I also see this voltage drop for a split sec. Add the Sub Amp drawing power, and the voltage drops bad when driving and playing system loud.
I am running 4 gauge RF 100% copper cable, ground is very clean and has no wiggle or movement.
battery, fusebox, and alternator cable has been upgraded to 0 gauge power and ground.
the 4 channel amp does not have any issue, just the sub amp.
Any suggestions?
Any suggestions?
