Power washing
hyah hytes
Jamaica
1500 big horn
Good day, I recently power washed under carriage Dodge ram 1500 Big Horn, then the next day I replaced one of the pressure Valve on the front tire with a regular valve. I'm awaiting a new pressure valve, then the guy put 40 psi in all the tires /22 inch rim. As I left the shop the abs light came on along with the trailer brake notification..on the dash it basically read all the brakes need serviced also hearing a noise from the rear. What could be the cause?. Thank you
markabby
kentucky
2020 Limited
tires should be at 36psi. as far as the brakes, most likely water is the culprit, especially using a power washer...that force could have entered into connections. i'd give it a few days to dry out.
the noise is anyone's guess.
