Pushrod
gb03
Oregon
Hi. I'm working on a 1987 D250 360
I went to change my rocker arms thinking that was my ticking noise but it was a bad lifter and pushrod. I ordered new pushrods and they have a ball on the end? They are not drilled like my original but everyone online says they will work. I can't imagine they will... what are you thoughts? Is the oil fed around the ball from the tube? I've not had to change the rods until now.
Thank you!
Dodge 1500 4X4
Rochester, NY
Do the OEM's have a drill hole in them, fairly certain oil gets pumped through the lifters to the push rod tubes to lubricate the valve train.
gb03
gb03
Oregon
Hi. I returned the pushrods and will try and find a like for like item. You just told me I made the best decision. Thanks for the reply!! Hard to make these decisions when I'm learning as i go and I have the stores saying "oh ya they will work" but I felt they were wrong too
u2slow
BC, Canada
Cummins 6BTA
I believe theres an oiling difference between the LA and magnum engines. Dont know if the lengths are the same.
