dhay13
- Apr 12, 2015
- 3,232
- 2,837
- 2018
- 2500 6.4L Hemi 4.10's 'Off-Road'
Have a 2018 2500 6.4 4.10's and have towed our 9000lb boat before but today towed a 9300lb travel trailer. Got all 3 CAT scale weights and hand calculated MPG towing.
Step-son bought a 2021 Grand Design Imagine 3250BH. Dry weight listed at 8600ish lbs. Real weight was 9240lbs one time and 9260lbs the next time (5 minutes later). One was with WDH bars connected and one was disconnected. Truck weight with me, 2 other guys, full tank of fuel, Equalizer 12,000/1200lb WDH in rear of bed truck was 8000lbs. Ticket shows 7580lbs but I was by myself on that one and the other 2 guys weighed 420lbs so that puts the truck at 8000 exactly.Oh, measured the rear wheel wells and loaded with bars connected it dropped exactly 1"
As for MPG, EVIC read 8.6 MPG when I was driving but he drove the last 2/3 and was between 70-75MPH and EVIC read 7.4 when we got back. Filled it up right before we left the dealer and filled up again when we got back. 105.2 miles traveled towing trailer and EVIC said avg speed was 41 MPH. EVIC read 7.4 but it took 15.720 gallons to fill it which works out to 6.69MPG
Next was with WDH bars disconnected. Front was a little light but still within limits on max axle weights. Didn't tow it this way but wanted a weight on it. This config gives 1240lbs of tongue weight
Last was with bars connected. With this config all numbers look good. All weight on front axle has been restored to empty config. Truck and trailer were perfect. Really could hardly tell it was there. The 6.4 was phenomenal and had no issue at all towing this. I was cruising at 65 MPH then step-son (speedy) drove the rest of the way and was doing 75 MPH. Truck had no problem running that and it still felt great.
