REAR DIFFERENTIAL SEAL SIZE PART NUMBER?
BMXGURU
boothwyn,pa
4.7l
2003 DODGE RAM 1500 ST 4.7 L 4X4 9.25 REAR DIFF SEAL ,I can not find correct size seal my seal is 3.25 outer diameter 1.75 inner diameter can't find any help greatly appreciated
Daw14
Try pinion seal.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Is it the Pinion Seal at the end of the Drive Shaft ?
Or the Axle seals at the end of each axle ?
Or are you thinking about the rear differential gasket, it would have about 12 bolts holding it on
