Rear Sway Bar
alucke
USA
I have a 2016 ram 2500 SLT and I noticed that my left rear sway at the sway bar link is lower than the right at the sway bar link. My left rear fender is about 3/4 lower than my right rear fender. does that mean my rear sway bar bent?
2003F350
6.7 CTD
It means something is wrong, but without inspecting it I can't say. Could be bent sway bar (but they're usually hard to bend), could be something else going on.
62Blazer
Midwest
The swaybar typically does not affect the ride height of the truck. I would suspect that something else may be bent or worn, like a spring is sagging, and that is what is causing the swaybar to be off.
