rebel gt
Static
Syracuse NY
towing 10k travel trailer wow is this thing squirrely blue ox sway system i might look into a different sway control
olyelr
Kewadin MI
Thats because your trailer is too large. Theres no way in hell i would regularly tow a 10k pound trailer with a half ton truck.
Administrator
Load the truck and trailer up as if your headed out camping and run it over a semi CAT scale, then drop the trailer and weigh just the truck. That will give you all the numbers to calculate tongue weight percentage and see how the WDH is transferring the weight. You want to replace the list weight on the front axle and the rear axle should weigh more than the front.
How the weight is distributed and how the WDH is adjusted will make a huge difference in handling.
