ramffml
- Jul 12, 2019
- 2,892
- 5,370
- Location
- ramforum
- 2019
- hemi 5.7
I'd like to improve my truck handling while towing. I will not be going over 7000 pounds in my trailer. However sometimes my trailer is loaded but my truck is empty, and even with an excellent WDH I find the truck "squirmy" and "mushy" on rougher roads. If I load up the truck with cargo near capacity (firewood in the bed) then it seems to handle better. On the freeway it cruises great, but rough country roads it can start to buck and squirm pretty bad.
My question, would you all recommend installing timbrens or better shocks like some bilsteins? What I like about the timbren is that they leave your stock ride alone when unloaded. What I'm worried about with them, is that if I'm carrying a smaller load (smaller fishing boat), the timbrens might engage occasionally and cause a "hit" that you feel.
I have tried air bags but didn't like them. These were the cheaper ones where you stuff them in between the coils. I have also tried sumo springs and they didn't have more than 1/4 inch clearance causing a terrible ride unloaded.
I've read good things about bilsteins and I'm willing to try them, but I suspect they will cost more because I'd get a shop to install them where the timbrens I can do that myself.
I've already tried the WDH route. First had a husky centerline, it bobbed pretty bad. The Anderson I use now is a static force, so the only moving part now is the coils in my truck vs the centerline spring bars which also flexed in the past causing issues. Anderson is way better for my setup, but would like to dial it in even more.
Tires are 20 inch michelin defenders aired at about 42 psi. They may be part of the problem, but not willing to change those out quite yet as they are amazing when I'm not towing and have about half life left in them.
Any reports, good or bad, or other ideas I haven't thought of, please post them!
