ROLL-UP INFO: FOTA 18.11.x & uC D/L 18.45.01 SW Update 13-17 RA3/Vp3-NA & Ra4 VP4-NA
clifford15
CTD
This is the store i went to https://ebay.com/usr/navi-expert-uk
just send them a message with year make and model and they will reply asking you to send pic of the screen with the software and code request
That is who I used to activate mine On Christmas Day 2018.
As an aside, if it wasn’t for my NAV I would not have found out my left front door speaker was blown. NAV sounds really weird through the dash speaker only.
RocketFoot
Southwestern PA
Is 18.45.01 still the latest update for 2013? I haven't seen any new updats for a while but i wanted to double check...
This is the site to check on the radio update
use Capital Letters
RocketFoot
Southwestern PA
use Capital Letters
Thanks! Looks like I am still up to date! I wish another update would come out for us 2013 drivers...I love change (especially when it is good!)
Update 1:
Uconnect_VP4,18.45.01-My13-17
Service Bulletin ID: FOTA and PopUp
Release Date: 2019-10-09
670hoth
Maine, USA
I have an RA4 CA radio I put in my 2017 Express. It works fine. What would I gain by updating the firmware? I would like to be able to change the screen background. It doesn't appear I can do that right now.
all i know is i could not update the software until i updated the firmware first
When i entered my VIN into the DriveConnect website, it spells it out
LumberJakl
Calgary, AB
6.7L 4X4
2017 RAM 1500 w/ 8.4A (RA3 - No Nav) and was running on 17.43.01. Checked Chrysler's website for updates, and there was none available for me (Out of warranty).
Downloaded the "Ra3 VP3-NA My13-17 v18.45.01 Fw update Link. (official uC Update 1 11/1/19)"
Flashed the truck, update completed with no issues.
Now currently running 18.45.01
670hoth
Maine, USA
I just updated my UConnect 8.4AN Canadian version part # 68224537AC that came out of a 2015 Ram Sport to 17.43.01. My truck is a 2017 Express black out edition. I used 'C:\Users\brian rolfe\Documents\Personal\2017 Ram 1500\Radio Climate Upgrade\UCONNECT_8.4AN_RA4_17.43.01_MY14_NAFTA -CAmaybe.zip' and the software update instructions I also found in one of the first several posts in this thread. One of the first things it says to do is "For non-Keyless Enter-N-Go™ turn the ignition ON / start the engine." I did that and started the update and everything seemed to progressing as expected and with the expected screens according to the instructions but it took an hour to finish. I haven't been in the truck very long yet but it appears that everything is working as expected so far. My question is, did i really have to run the truck for an hour? Who want's to do that with a Ram 5.7? I suspect I could have just had the key in the run position and not had the truck running. Is this correct? After I live with this for a few days to make sure there are no bugs I will do the upgrade to 18.45.01.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
You can also put a battery charger on it if you don't want to start the truck... The issue is that if the battery voltage drops too low during an update... It will very likely Brick the radio (can sometimes happen anyway).
670hoth
Maine, USA
Oh, ok, that makes sense. I still have to do the 18.45.01 update. I assume it like we takes quite a bit less time but I may just do it with the battery charger. We all know idling these hemis for a long time can possibly contribute to the lifter problems. Thanks for putting this thread together and collecting all of this info and thank for the additional info here! It's very much appreciated!
jcd302
I have a 2015 RA3 (from a Cherokee) in my 2017 BigHorn. Currently at 15.30.2 and have been trying different files and reading the messages leads me to believe I need RA3 17.11.07 MY17 before I can go to 17.43.01 then 18.45.01. I have the latter 2 saved, but I am having trouble finding 17.11.07 for the 8.5A. Tried the RA4, but it told me I need the VP3 instead of VP4.
Where can I download the RA3 version of 17.11.03?
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Should be able to go straight to 17.xx.xx then 18.xx.
Did you use this link for the Ra3 17.x files?
jcd302
I tried that version. If I do 17.43.01 I get files not supported. I had 17.11.01 but for the RA4 and it said I need the VP3 not VP4. So I have determined that I need the 17.11.01 MY17 for RA3. It seems to be the only one I haven't tried and of course I can find RA4 ones all day long. :rolleyes: I am currently at 15.30.2 if that matters. Seems it doesn't want me to go directly to 17.43.01
CamronB143
Edmonton, AB, Canada
HEMI 5.7L
Just want to give a big thank you to @Mpgrimm2 for all the info on upgrading radio software and to report my success to help any other Canadians
2014 Ram 1500 for Canadian market, radio is 14 RA3/VP3-CA.
Started today with v13.51.11, P/N 68224538AH
UConnect says no further updates, but after a trip to the dealership for laggy volume controls and mic not working after last service, found out that my software was behind by what they claimed was 4 versions and would need a full day of tech time.
Post #9 on this thread had my FW (if you hover over the link in the post, you will see "_NAFTA" at the end, so it works for -CA radios as well!) :
2014 RA3/VP3-NA (PN: 68224531Ax)
- v17.43.01 Fw Link (removes Dual Cam Support) and Update Directions Link
List of changes: TSB 08-068-18 My13_My14 17.43.01.pdf
MD5: C34A8C97BBF018ACA08E2D5DEAD9CABA
Updated using those two files, got me from 13.51.11 to 17.43.01, P/N was updated to 68224538AN
One note: I didn't get multiple prompts to update FW versions, it almost looked like it was failing a couple times at first (it would say loading part 5/14, say, and then say it needed to restart and start from 1/14 again, did this a couple times). I was looking to see how I could recover what I thought was my bricked radio, but then realized my blower was on and that those controls went through the radio ECU, so I shut that off (pressed "Off" on the fan speed dial), and once I did that, it completed all 14 parts and declared it was at 17.xx.xx. Coincidence or solution, I'm not sure.
Then it was this link from Post #3 of the thread you're in now (another post by Mpgrimm2 said that this is a broad update due to GPS sync bug):
- Ra3 VP3-NA My13-17 v18.45.01 Fw update Link. (official uC Update 1 11/1/19)
MD5: DB071D0E5598D0F1C80ED6E8082B3B10
That got me from 17.43.01 to 18.45.01, P/N still 68224538AN
So my advice for anyone looking to upgrade a Canadian unit: look for the "_NAFTA" in the FW file!
And thank you again to @Mpgrimm2 for sharing your expertise!
Jv6293
Hello and thank you for any feedback you can provide. I have a 2015 Ram 1500 with a 8.4AN RA4 radio from a 2014 Durango and the current firmware is 16.16.13. Got in touch with the company that sold and installed to radio to which they gave me the 18.45.01 update files but I couldn’t get the update process started on my radio. I stumbled upon this post with the diagram saying my firmware needed to be taken to the dealer and wondering if that’s going to be expensive, if so is it maybe worth going aftermarket instead of trying to retain to the head unit?
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
You have to update the radio to v17.xx.x before you can go to v18.45.x.
Can't say if the 14 ram 8.4 Ra4 v17.xx.x files here would be compatible or not with a Durango version PN.
Jv6293
I tried the Ram files and they were incompatible like you said although it was nice to see it finally do something for once. Any idea how I could get the right version?
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Can the person you got the radio from get you the 17.11.x or 17.43.x file for it?
Otherwise you need the vin of a Durango with that same year/model radio and take a blank USB drive to a dealer and see if you can get them to download it on the drive for you (cost $$ most likely)
Jv6293
I'm going to email the company again tomorrow to see if they can verify which vehicle it came from.
This is the error report I got back from the usb.
********SOFTWARE UPDATE LOG********
Starting Update
Total units to update: 3
Installing unit 1 SYSTEM CHECK
Got the unit installer for SYSTEM CHECK
System Market matches
System Product matches
system_module_check: Part_number 68239117
This software update is incompatible with this radio. Update cannot be performed remove USB stick to return radio to normal operation.Visit DriveUconnect.com for correct software
ERROR: This software update is incompatible with this radio. Update cannot be performed remove USB stick to return radio to normal operation.Visit DriveUconnect.com for correct software
Software Update failed, see 'swdlLog.txt' on the USB stick for more details
Eject USB for RESET
*Update* After trial and error I was able to find the compatible file, I installed the 2015 Ram 17.11.x files on the unit and will update after trying 18.45.x.
*Update2* 18.45.01 was successfully installed on the unit and everything seems to be working fine. The navigation says it needs calibrating but I’ll do that tomorrow.
I appreciate the work you’ve done providing the files needed for people like me to update their radio thank you!
Runninstuff
Cummins 6.7
@Mpgrimm2 I have a 2014 RAM 2500 CCLB 6.7L that originally had the 5.0 Radio. I upgraded to a 2016 8.4 RA3/VP3 Canada version with dealer installed Navigation. I upgraded the 8.4 to the 2016 RA3/VP3-NA 17.43.01 file first then to the 2016 RA3/VP3-NA 18.45.01 file next. The fact it was a Canadian radio did not cause me any issues, so far. Just wanted to share this info.
