Running boards from 1500 fit 2500
Dudleedawg12
Stockton
I have a 2023 Laramie 1500 switching to a 2024 Big Horn 2500 hoping my burg bars from the 1500 will fit the 2500
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
The Running Board Brackets only attach to the CAB, nothing attaches to the Bed itself.
So, if both Rams are Crew Cabs, you are good length wise
So as long as the brackets attach to the cabs body work & not the frame, you should be set
D
Dudleedawg12
Stockton
Thank you I will check, but believe they do attach to cab body the mounting studs are factory equipped
olyelr
Kewadin MI
The 1500 cabs are completely different than the 2500 cabs. They probably wont work.
DeckArtist
Elmo, Tx
And the frame is different also. Doubt the mounting spots will line up, however, with the flat factory boards like I have they are very adjustable.
