Spark Plug Change DIY
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Have a safe trip home. I enjoyed my tours in Japan and found it a little hard when I finally left.
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
Now that you mention it....there's a lot of ''little hard'' in Japan from what I've heard,lol.
Jeremy73
Started changing my plugs, got to number 5 on the passenger side and it's stuck. Buddy of mine suggested using "PB blaster " anyone every used that?
Jeremy73
Also, ya say to drop the socket in first, well when coming back out after replacing plug, I know ya can knock the plug socket off the extension with a flathead, but then how do ya get the socket back out! Thanks.
Redtruck-VA
Virginia
You can buy one of these at the local parts store and is all I use to remove and replace all of my spark plugs
justin13703
MD
Yes spray some penetrating fluid down the spark plug hole and let it sit overnight if possible. It should come right out
rocket
connecticut
was 2006
was a HEMI 5.7
yep, lotta 3 valve furd owners swear by it......squirt it in and walk away for an hour........should work fine.:buffer:
rocket
connecticut
was 2006
was a HEMI 5.7
I used the small extention.........snapped it in an took it out. But what I did, was loosen the plug but still in the threads....then just removed the socket without the plug.....The plug I grabbed with a cut garden hose.....installed the same way.
Jeremy73
So ya tightened it up with a garden hose? That's pretty neat. Never seen that. I'm not too awfully gifted when it comes to being a mechanic. Most I can do is plugs (with some helpful advise) alternator, oil, and reg maintenance stuff.
rocket
connecticut
was 2006
was a HEMI 5.7
just to finger tight, ya work in the socket for the 1/4 turn tight....hard to get a torque spec on the rear driver side plugs....but after ya tighten the other 12 ya sorta get a feel for the last 4.
Jeremy73
Ah Gotcha. Thanks for the help
Jeremy73
Ok guys. Got all my plugs changed, except for the stuck one, used liquid wrench and pb blaster, no luck. Even tried a cheater bar on the ratchet, still no luck. Guess it's seized up. All 15 other plugs came out very easily. And this thread helped me a ton with the back plugs. Thanks for the help. Not sure what I'm gonna do about the seized up plug, I guess see how much a mechanic would charge, but it's it's a lot I won't mess with it until I need too.
Sent from my iPad using Tapatalk HD
rocket
connecticut
was 2006
was a HEMI 5.7
makes me think that one plug is from the factory....never changed...ya could try heat......but that's risky.
Jeremy73
I tried getting it at slightly less that norm op temp. No luck.
Redtruck-VA
Virginia
A friend of mine just had this problem on a chevy at his shop and actually broke the top of the plug off at the threads. Unfortunately he has to take the head off to fix. With the hemi I would soak it steadily for a couple days with PB or other rust penetrator. Let it soak thoroughly. And then try to remove the plug. If the plug breaks off the core will probably come out with the top piece and there will be a hole allowing air to past. The head will need to come off at that point. Good luck.
