Steering column issue
Ed Brock
Oak Grove, Or
1985 & 2015
318 & 3.0 Diesel
What I'm looking for is a factory blue print of a tilt steering column for my '85 Dodge W150.
Does anyone have such an item? Does anyone have the upper and lower shaft bearing part numbers?
PaPitt
Stephenville TEXAS 76401
5.9L
NOW I do understand your question. But I seem to have better & Cheaper luck .. Just going to the wrecking yards & grabbing a new column .
Change out the Ignition switch . & Normally put my Steering wheel on it.
.. & If colors are an Issue then used Simms spray for Vinyl..
& other color matching spray can will fix other issues .
Just in case you have issues inside the column like I have..
I'd rather take a whipping than ty & fix a column .
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
