Steptember Sale!
RealTruck
Preferred Vendor
Happy Steptember Ram Forum!​
We are proud to offer a very special deal for you all this month! We have partnered with N-Fab and Go Rhino on this one to bring you some outstanding steps with unbeatable pricing!
Pricing is going to be by PM or email only to take part of this huge sale!
I am going to highlight a few of our top sellers but if there is another N-Fab or Go Rhino board or step that you are interested in please don't hesitate to reach out as this discount does apply to their entire line! We specifically chose these two brands to work with due to the quality of their products and the ingenuity their steps offer.
We will be running this special for the month of September, as the name suggests, so do not wait to take part in this limited offer!
GO RHINO DOMINATOR D6 RUNNING BOARDS
  • Durable steel tube construction with raised hex pattern stepping area
  • Protected with black textured powdercoat for longevity
  • Dual purpose design allows D6 steps to function as running boards or rock sliders
  • Mounts tight for max ground clearance
  • Optional bolt on 4" drop steps available
  • 300lb weight capacity
  • 5 year warranty
GO RHINO RB20 RUNNING BOARDS
  • Constructed from one piece of 16 gauge zinc coated steel
  • Thickness offers optimal strength to weight ratio.
  • Zinc coating seals the steel, offering additional corrosion resistance
  • They come with a rubberized powder coat that adds to the grip of the step area considerably and increases durability
  • 5-year warranty
  • 7.5” wide
  • No drill
N-FAB TEXTURED BLACK CAB LENGTH PODIUM STEPS
  • Sits high and tight to the vehicle
  • Stainless steel, 1- piece construction
  • Drop down step design to allow for ease of access on stock or lifted vehicles
  • 4.75” wide
  • 5-year warranty on finish and limited lifetime warranty on workmanship
  • No Drill
N-FAB BLACK EPYX STEPS
  • Drop down step positioned at each door with 15” inch stepping surface that are 4 inches deep
  • Modern angular design that fits tight to the vehicle body for a modern clean look
  • Carbon Steel construction
  • Two-stage powdercoat finish that provides a sealed, corrosion-resistant finish
  • No Drill
N-FAB NERF STEP RS
  • Constructed from heavy duty 2" steel tubing
  • Dual layered black powder coating for superior corrosion resistance
  • 5" wide step plate
  • Die-Stamped punch plate adds maximum traction
  • Mounting brackets are welded to the steps
  • Mounts to rocker panel
  • 5 year warranty on finish and limited lifetime warranty on workmanship
RealTruck
RealTruck
Preferred Vendor
Last week to get these lowest prices on N-fab and Go Rhino steps!
