Tailgate bumper step
dieseldave
Little Suamico
my tailgate bumper step is always stuck. I need to use a pry bar and some lubricant to make it functional. Is there any way to losen it up ?
DanAR
Arkansas
Is this one of those spring loaded, fold up steps mounted order the left corner of the bumper? That spring is really strong but probably a shot of good penetrating oil on the hinge points like Tri-Flow should loosen it up.
Stavinksi
Midwest
Is this something we should be doing preventative maintenance on? Mine swings ok at the moment
Administrator
dieseldave
dieseldave
Little Suamico
I tried using Film Fluid . It works for a little while, then it gets stuck again. Maybe I just don’t use it enough.
DanAR
Arkansas
It probably does get a lot of road spray off the tire and even splash guards might not cut that down much since it’s inboard of them. Frequent lubricant sprays with something is a good idea.
KeithP
Hemi 5.7 VVT
I’ve had two truck with them. No issues with either. I do extend it and wash it every time I wash the truck, which is frequently.
